Transverter with split IF
Not sure if I am posting this is the correct forum, but I borrowed a 2 meter transverter from a friend and it appears to have a split IF. I have used transverters in the past that had a common IF. Trying to get this hooked up to my 6400 but not sure how to connect it. Any help would be appreciated.
K4QXX
Burch
Hi Burch... it would help if you could post some specs/info about the transverter -- manufacturer, model #, etc. Is it single band or multi-band (multi-band might explain the split IF?).
Then we can help you more (I hope :-) )
Not to worry about 'correct forum', I'm sure Mike or other community moderators will move it where appropriate...
Hi Burch, the XVTR port from the radio goes to the transmit port of the transverter.
The RX IN port from the radio goes to the receive port of the transverter.
Set your receive antenna to RXA and transmit to XVTA.
Plug TX 1 (or whichever RCA TX jack is free) to PTT of the transverter. Use TX Band Settings screen to select the appropriate RCA TX jack.
In my case, I key the transverter with TX2 and the 2 meter amp with TX3. TX1 is already occupied with my HF amp. Use whichever makes sense in your case.
The model is a Down East Microwave 2m25 LDPA. It has has a following ports on the back of the transverter.
TX
ANT/RX
AUX
Trans
PTT.
BYPASS
Hi Burch, the LDPA is a Low Drive Power Amplifier, not a transverter. It is designed to take the 2 meter output from a Flex 6700 and amplify it to a usable level (25 Watts in this case). It will not work directly with any Flex radio except for a 6700.
That's what I thought after looking at the model number. I have the 2MLDPA 75 watt version for my 6700. I was trying to hook this up to my 6400. Thanks for the quick response.
HI Burch... if the person you borrowed the 25W LPDA is interested in selling, I would be interested.
My email on QRZ.com is good.
I will ask him.
I too have just purchased a 6400 and a 5Band Q5 transverter with split IF. I need help setting all of it up any chance someone could call me? 325-450-3076 Jim WM5L0
Hi Jim, I'll give you a call in a few minutes.
Hi Jim, no answer at that number.
TY Len for the call I am close TTYL0
Lost your number Len any chance you might holler back at me0
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
