My 6700 wont Tx, I get a PTT req under the TX on the botton status bar of SmartSDR
Dan Moore
what's causing the PTT req to be displayed and how do I fix it.
Hi Dan, do you have the PTT switch plugged into the PTT jack or the TX REQ jack? It needs to be in the PTT jack.
The other place to look is on the TX Band Settings screen (can be opened by choosing Settings > Radio Setup… from the main menu in SmartSDR for Windows). Then verify that the related TX Req fields are not checked unless you're using that feature as shown here:
