V2 and V3 Profiles
Harry W0LS
I am replacing my 6700 radio with a 8600. 6700 was running v2.12.1 software. Will the profile created with that software be compatible with V3 software on the 8600?
Thanks and 73,
Harry - W0LS
Best Answers
Hi Harry, while I can't say definitively 'yes', I suspect that your 2.x profiles can be iimported to v3 with no problems. Just make sure to EXPORT all your profiles from the v2 machine and then IMPORT to the v3 after you have it set up and working on its defaults.
ok…thanks Don for the info…we will give it a go…
Harry
Just fired up 8600. Everything worked as expected. Moved V2 profiles/memory to V3 and it worked perfect. Thanks Flex for seamless esperience!
Harry - W0LS
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
