For some reason I am having no output to my headphones.
I do not use external speakers as my hearing is not as good as it was 54 years ago. I have the volume set to halfway. Made sure they are not muted. What am I missing?
    Can you post a screenshot of SmartSDR?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi K6FA… where are your headphones plugged in? To the Maestro, to the Flex, to your PC? That, plus the screenshot of SmartSDR will help us figure out what's happening.
  • David_K6FA
    David_K6FA Member ✭✭
    There was an error rendering this rich post.
    Hi David, if you email me your screenshot, I will post it here on your behalf (I am assuming that the rich text above is referring to a picture).
    KD0RC at arrl dot net
  • David_K6FA
  • David_K6FA
    Problem fixed
    David - K6FA
  • David_K6FA
    The volume on my PC was turned off.
    David- K6FA
