Can't open new Panadapter with version 3.9.18
Carsten G0SYP
I've just installed v3.9.18 (previously latest 3.8) on my 6600M. I am usually using it in SmartControl mode.
I used to have 2 windows, the main window with 2 pandapters on 6m and another window with another panadapter on 2m (via Transverter). The configuration was saved as a profile.
After the install I reloaded the profile. The main window with the 2 6m panadapters opens fine and I can see the second window open and closed immediately.
The same thing happens if I click on the New Panadapter button.
Anyone have the same issue or any ideas, please?
73 Carsten, G0SYP
73 Carsten, G0SYP
I should have said that I of course also installed 3.9.18 on the PC.0
I found an issue with my Maestro while in SmartControl with two slices open. I reported it several days ago with a ticket. My best guess…it appears to be a software issue. Others have reported a problem…I'm sure Flex is in the process of addressing the problem.
