SmartSDR v.3.9.18 slice configuration displayed on radio restart.
Recently upgraded my 6600M to v.3.9.18 without any problems. I have found what seems to be a small bug. It does not matter what slice configuration I have set up on the radio, when I shut down the radio, the next time I turn it on the 6600M always comes up with the slice configuration that was first displayed after the upgrade. It is as though the current configuration is not being saved upon shutdown. Reverted to the previous v.3.8.23 and it does not have this problem.
Has anyone else observed this behavior?
73, Ted W4NZ
Check the setting for Profile auto-save. Maybe you think it should save but actually is set not to.
If this isn't it, sorry, it just came to mind because this is a change in 3.9.18
Hello Erik, that was a good suggestion, thank you. But upon checking, "auto-save" was enabled. I am using one of the default global profiles, SO2RDefault.
73, Ted W4NZ
