V3.9.19 Interlock is preventing transmission
GM. Running 6600 in standalone configuration with Windows 11. Since upgrading to v3.9.18 (with any changes from v3.8.21), I am routinely seeing an error message when starting SmartSDR - Interlock is preventing transmission. Is anyone seeing this? Fixes? TX rollover on SmartSDR panel notes PTT:
  • Craig Willison
    Craig Willison Member ✭✭
    Sorry, Message title typo - should have noted v3.9.18
  • Erika - KØDD
    Erika - KØDD Member ✭✭✭
    Yes i saw it pop up yesterday starting everything. When it was done booting up all the software the radio was not interlocked.
  • Craig Willison
    Thanks Erika for letting me know your experience re this… that is what I have also experienced after SmartSDR startup with the error message - all seems to be working fine. Will leave the rest to Flex! 73, Craig
  • Wayne VK4ACN
    Wayne VK4ACN Member ✭✭✭
    check TX delay. Mine had been reset to 0 after upgrade. I usually use 40
  • Craig Willison
    Hello Wayne, thanks so much for your suggestion… I was hoping that this might be an answer, but my TX delay is still at 40, as before. Will continue to search! 73, Craig
  • Piero Ferrua
    Piero Ferrua Member ✭✭
    La stessa cosa succede anche a me e non solo, se trasmetto con più di 40W la radio si spegne, la spia lampeggia rosso 2 volte (softwere error) qiondi da sola la radio si riavvia.
  • Piero Ferrua
    Dimenticavo, anche se usato in remoto (maestro) avviene la stessa cosa .
    Sul Maetro Tx delay era a 0, cambiato in 40 ms.
    Grazie e 73 cordiali
  • Craig Willison
    Thank you Piero for sending over your comments / experience. FlexRadio support is still working to determine why this SSDR alert message is appearing. 73, Craig
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    I see it as well…
  • Craig Willison
    Thanks Mick - have forwarded…
