V3.9.19 Interlock is preventing transmission
GM. Running 6600 in standalone configuration with Windows 11. Since upgrading to v3.9.18 (with any changes from v3.8.21), I am routinely seeing an error message when starting SmartSDR - Interlock is preventing transmission. Is anyone seeing this? Fixes? TX rollover on SmartSDR panel notes PTT:
Sorry, Message title typo - should have noted v3.9.18
Yes i saw it pop up yesterday starting everything. When it was done booting up all the software the radio was not interlocked.
Thanks Erika for letting me know your experience re this… that is what I have also experienced after SmartSDR startup with the error message - all seems to be working fine. Will leave the rest to Flex! 73, Craig
check TX delay. Mine had been reset to 0 after upgrade. I usually use 40
Hello Wayne, thanks so much for your suggestion… I was hoping that this might be an answer, but my TX delay is still at 40, as before. Will continue to search! 73, Craig
La stessa cosa succede anche a me e non solo, se trasmetto con più di 40W la radio si spegne, la spia lampeggia rosso 2 volte (softwere error) qiondi da sola la radio si riavvia.
Dimenticavo, anche se usato in remoto (maestro) avviene la stessa cosa .
Sul Maetro Tx delay era a 0, cambiato in 40 ms.Grazie e 73 cordiali
Thank you Piero for sending over your comments / experience. FlexRadio support is still working to determine why this SSDR alert message is appearing. 73, Craig
I see it as well…
Thanks Mick - have forwarded…
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
