Analog meters
K6JV
K6JV Member ✭✭
Updated to latest release with the analog meter option. Is there a way to change meter from peak to average? When in standard configuration, it will go to 20 over 9 on a signal and stay there. Takes several seconds for it to return to noise floor level.
Best Answers
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited May 2025 Answer ✓
    Yes. In Maestro or M-model, tapping on the lower third of the neddle will advance through the options for meter display, There are four options for TX and two for RX. SO you have to tap through the combinations. From default, tapping four times will get you to tx Power and rx S-Meter ( no peak hold)
    Unfortunately, the options are not currently persisted. Re tap each time you start Maestro/M
    AL, K0VM
  • K6JV
    K6JV Member ✭✭
    Answer ✓
    Thanks Al, exactly what I was looking for.
  • Rick N0VT
    Rick N0VT Member ✭✭✭
    Here's a vote for the ability to save my analog tx select/rx select choices. In one of the profiles, maybe?
