How to save Global Profiles to a Laptop with an 8600M
David43
When in Profiles under MENU there is no option to export the Global Profiles to my Laptop. Please help,
David, K1MT
David,
The 8600M/Maestro can not directly export profiles to a windows device. You will need to load and Run SSDR on the windows machine and do the export from SSDR. (Yes, SSDR on a PC will connect to the 8600M )
You will need to do the same to import profiles.
AL, K0VM
Thanks so much,
David, K1MT
