SSDR 3.9.18 and TGXL
Using SSDR 3.9.18 and the TGXL Integration into SmartSDR for Windows, I find that I cannot choose which of my three antennas is selected on my TGXL 1x3.
It looks like I will need to use the TGXL Utility instead of the new TGXL Integration into SmartSDR for Windows. Too bad…
73 de K1ESE
John
The 1x3 antenna selection is not integrated. The TG XL 1x3 will remember the last antenna used on each band though. So just go through each band and select your best antenna and the tuner will then select the best when band changing.
73 Dave wo2x
Dave -
I have two doublets. Both cover 40m through 6 meters with the TGXL. I switch back and forth between them to see which is best on a particular signal. I can't do that with the TGXL Integration into SmartSDR for Windows. The feature is of no use to me. Disappointing.
73, John K1ESE
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
