Can you move the Analog meter
k4em
k4em Member, Unconfirmed ✭✭
I can grab the dark gray bar above the meter and move it to a different place on the display, but it snaps back to original location. Is there a way to move it around and stay?
Dave
k4em
    Hi Dave, the meter can only be moved within the control container.
  • W1WRA
    W1WRA Member ✭✭
    You can change its position in the Radio Control panel (like any item). You can also “pop” the entire panel off the panadapter screen. Depending on your goal, this might help you place the meter where you want. However, you can’t “pop” off just the analog meter and place it anywhere. If anyone knows otherwise, let me know.
  • Trucker
    Trucker Member ✭✭✭✭
    That's the feature I like about the Woodbox meter. Put it where you want it and it stays there. Even when you restart SmartSDR and the meter.
  • johnn1jm
    johnn1jm Member ✭✭✭
    But the Woodbox meter can only read one slice, correct?
  • N5NHJ
    N5NHJ Member ✭✭✭
    You can start several Woodbox meters, each one connected to a different slice. Just create a CAT interface for that slice.
  • johnn1jm
    johnn1jm Member ✭✭✭
    Thanks. Didn't realize that.
