TGXL integration with SmartSDR v3.9.18
Please disregard. I did not see I needed the new firmware0
FYI - the new required TGXL version is not currently available here or on 4o3a. Here is the 4o3a downloads.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6600 SSDR V3.8.23
TGXL 1.1.20
PGXL 3.7.32
Win11
came to say the same
The TGXL v1.2.17 firmware is now available on the 4O3A website here:
do you have to click on the GENIUS integration tabs as well; downloaded 1.2.17 worked fine just reentered new 8600M serial numbers
now there is no difference between stby and bypass the tuner works in bypass mode
@Arnold Goldman what Genius products do you have? Are you using just the Flex or do you have other radios? This will determine how to configure the different menus
73 Dave wo2x
have all genius products PGXL, TGXL and 8600M ALL FLEX TNX
got response from flex that flex radio tabs are connected and dont have to configure genius tabs; only for the antenna genius ; but tgxl still locked up tnx for any help
On the Maestro C and 1.2.17 I can see the TGXL and can switch from operate to standby to bypass.
But can I start a tuning cycle on the TGXL from the Maestro with out transmitting?
Thx
Q-But can I start a tuning cycle on the TGXL from the Maestro with out transmitting?
Yes, when the TG is in operate, push the "ATU" button on the Maestro to tell the TG to find a tune solution.
Alan. WA9WUD
That worked. Thank you!
- 383 Community Topics
- 639 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
