Can you move the Analog meter
Dave
k4em
Hi Dave, the meter can only be moved within the control container.
You can change its position in the Radio Control panel (like any item). You can also “pop” the entire panel off the panadapter screen. Depending on your goal, this might help you place the meter where you want. However, you can’t “pop” off just the analog meter and place it anywhere. If anyone knows otherwise, let me know.
That's the feature I like about the Woodbox meter. Put it where you want it and it stays there. Even when you restart SmartSDR and the meter.
But the Woodbox meter can only read one slice, correct?
You can start several Woodbox meters, each one connected to a different slice. Just create a CAT interface for that slice.
Thanks. Didn't realize that.
- 389 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
