TGXL integration with SmartSDR v3.9.18
I did the upgrade with no problem on my 6400 and I am using a standalone TGXL with FW:1.2.11 I don't see the menu item to integrate it into the software. Am I missing something?
  • gbird
    gbird Member
    Please disregard. I did not see I needed the new firmware
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    FYI - the new required TGXL version is not currently available here or on 4o3a. Here is the 4o3a downloads.
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
    6600 SSDR V3.8.23
    TGXL 1.1.20
    PGXL 3.7.32
    Win11
  • EricZimmerman
    EricZimmerman Member ✭✭
    came to say the same
  • Eric-KE5DTO
    The TGXL v1.2.17 firmware is now available on the 4O3A website here: https://4o3a.com/images/downloads/tuner_genius/TunerGeniusUtility_v1.2.17.exe
  • Arnold Goldman
    Arnold Goldman Member ✭✭
    do you have to click on the GENIUS integration tabs as well; downloaded 1.2.17 worked fine just reentered new 8600M serial numbers
  • Arnold Goldman
    now there is no difference between stby and bypass the tuner works in bypass mode
  • David Decoons, wo2x
    @Arnold Goldman what Genius products do you have? Are you using just the Flex or do you have other radios? This will determine how to configure the different menus
    73 Dave wo2x
  • Arnold Goldman
    have all genius products PGXL, TGXL and 8600M ALL FLEX TNX
  • Arnold Goldman
    got response from flex that flex radio tabs are connected and dont have to configure genius tabs; only for the antenna genius ; but tgxl still locked up tnx for any help
  • Doug Wilson
    Doug Wilson Member ✭✭
    On the Maestro C and 1.2.17 I can see the TGXL and can switch from operate to standby to bypass.
    But can I start a tuning cycle on the TGXL from the Maestro with out transmitting?
    Thx
  • Alan
    Alan Member ✭✭✭✭
    Q-But can I start a tuning cycle on the TGXL from the Maestro with out transmitting?
    Yes, when the TG is in operate, push the "ATU" button on the Maestro to tell the TG to find a tune solution.
    Alan. WA9WUD
  • Doug Wilson
    That worked. Thank you!
