SO2R SW Setup SSDR & 4O3A....?
Jens DL7AUO
in Contesting
Hi all,
Is there any document or video explaining in detail how to setup the software for SO2R using all the 4O3A components? I might be hunting an software issue with SSDR for Mac + 4O3A and would like to see if all setup correct. I would like to double check with a detailed setup discription for Windows, incl. a power genius, tuner genius, antenna genius before going back to Markus.
Any resources you could reference esp. for the SW setup, I am aware of the 4o3a station setup diagrams but not of any Windows SW setup.
Jens
There are some software references in this
It came to mind when I read your question though you probably are already aware.
