SO2V(R) CW Setup With N1MM+ on 6600
N6WT Kent
I have setup my 6600 to do SO2V with N1MM+ using the instructions here
My problem is that when I hit the \ to switch between entry windows, the Sidetone is turned off on slice A. I can turn it back on, but the next time I hit \ it turns off again. How to fix??
Kent
N6WT
Okay, I figured out the problem. Disreguard.
TNX
Kent
N6WT
