Flex 6600M Profiles manager.
I have about 20 profiles loaded but not in specific order in the Profiles drop down panel. I would like to re-arrange the order in the panel to make the Profiles consecutive. For example, I would like Profile Antenna 1 10m CW to be above Profile Antenna 1 12m CW which would be above Profile Antenna 1 15m CW.
Is there a way of doing that?
Thanks for reading, Mike, WM5DX.
Hi Mike, you just need to name them in the order in which you want them to appear.
For mine, although not obvious, I have an additional 2 spaces from the dash of the single digit bands (2 and 6), a single additional space for the 2 digit bands (80 - 10) and no additional spaces for the three digit bands (160).
Another approach is to just name them with a leading number or letter:
" 1 - 10 CW"
" 2 - 10 SSB:
" 10 - 160 CW"
Note that leading spaces or zeroes are needed with numbers so that 10 does not come before 2. If you have more than 26 profiles (as I do), you will want to use numbers instead of letters.
