Using 6500, PGXL and TGXL and 2x8 ant switch
SteveKC5TJT
SteveKC5TJT Member
I have a 6500. I want to run Ant 1 into the PGXL A and TGXL A and go out to one side of my Array Solutions 2x8 antenna switch. Then do the same on ANT 2 and B on the PGXL and B on the TGXL. When I TX on Ant 1 all is good. I go to ANT 2 it’s actually transmitting on Ant 1 and 2 at the same time. This has got to me a setting right?
  • SteveKC5TJT
    SteveKC5TJT Member
    I simply want to be able to change to ANT 1 or ANT 2 and transmit and receive off one or the other side independently.
  • David Decoons, wo2x
    first make sure you have latest TG Xl 1.2.11 and PG XL 3.8.9
    In PG XL configuration, make sure CAzt is unchecked for A&B. In Flex tab set A to radio s/n, Ant1 and LAN keying. B should be Ant2, Radio s/n, and LAN keying
    In TG XL configuration Set Flex tab to radio s/n & Ant1. B to s/n and Ant2.
    In Genius Integration tab make sure Power Genius and Antenna Genius are unchecked.
    In radio on Settings/Radio Setup/TX tab, set TX Delay to 30.
    If all this is checked, you could have a bad relay in the radio. How are you controlling the antenna switch?
