v: 3.8.23 / FLEX 6400
telemetry2
Member ✭
Adding a channel in the Memory Channels Menu, doesn't allow for a Power Level to be set.
That is correct. You can, however, create profiles that will save RF Power. Typically, you would have one profile for each band/mode combination that you want.
If you are keeping these power settings so that you don't overdrive your amplifier, you might want to look at DDUtil. If you are running a KPA 500, then take a look at the Flexicraft Utility thread on this community.
I would like to know where DDUtil is located. I found that the Memory Channels Menu does store the
power that was set for it. It's hidden.0
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
