DAX TX is disabled when pressing PTT
dserafine
Member ✭
I am running MAC OS 15.3.2 and SmartSDR 2.9.68 connecting to an 8600 running 3.8.23. The MAC is attached via USB to a nice mixer which enables me to use various MICs. I created a new microphone profile connecting to the MAC with DAX TX enabled. When I press PTT, DAX TX is disabled. I have to press PTT then turn DAX back on to transmit. It's very annoying like double mute. How can I fix this?
when running macssdr there is no reason to use DAX for audio for ssb mode. just set audio
in systen setting select for input your usb based mixer this will be the mic macssdr will use
see sectio 3.4 of macssdr manual for mic/spker slection
here i use the builtin mic on my macbook air…you should see you sub mixed show in the list
also check mic is shown for macssdr
Paul K3SF
I feel fortunate someone is here to catch my mistakes. I thought for sure I had checked the settings, even double checked. I guess not. DAX RX was able to return audio from the radio. So, I figured that DAX TX was the answer. Thanks Paul.0
glad to help…enjoy the great work Marcus does with flex and the MACS
Paul K3SF
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
