Spot Remove All Command
Per the Wiki, the command to remove a spot is: C[D]<seq_number>|spot remove <spot_index> Where <spot_index> is the specific spot you want to remove. Question: What is the commnad to remove all spots? Alan WA9WUD
Best Answers
If you have not already found the answer "spot clear" should work.
Done.
Just released FRStack 3.1.26.55
Added Radio Memory REST API, Radio SPOTS REST API, Hot keys for CWSPEEDUP1 CWSPEEDDOWN1 and a new feature where Slice B tracks Slice A frequency w/ rev direction feature. The last feature can be used to work satellites.
FRStackWebApi releases will follow shortly.
Hi Alan, I haven't tried this yet, but it seems like you could do a for loop (or whatever the Node Red equivalent is). Increment spot_index from 0 to 999 in a remove command. Just ignore the messages about invalid spot_index. I also wonder if a spot_index of ALL would work.
Len, KD0RC
Thanks, Mark. I will give that a try. Perhaps a candidate for a REST command in the next update?
Alan
I am working on a simple macOS app to clear all spots (since Marcus's app doesn't do it), and using WireShark with Windows SmartSDR in a VM, I discovered that the command to clear ALL spots is:
C[D]<seq_number>|spot clear
Easy-peasy.
I've added an "Issue" to the Flex Wiki to have this command added.
