6700 + XVTR KUHNE TR 144 pro
Greetings to all
Can anyone help me with this setup?
How to use a 6700, how to use the KUHNE converter and how to use it? what is the RF power capacity? Does anyone use this setup?
thanks to all in advance 73 Oreste
  • Mr Radio
    Mr Radio Member ✭✭✭
    Hello OM,
    On 2m band you can use a RF amplifier designed to work with 6700, much simpler solution.
    Kuhne makes them. SSDR manual has a chapter which shows how to setup a converter.
    Tom
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    edited April 2025
    Hi Tom… I checked the Kuhne website and other messages on this forum, and I can't see any direct reference to a Kuhne amplifier capable of working with the 6700's LP output.
    Can you point me to the unit you're talking about?
  • Mr Radio
    Mr Radio Member ✭✭✭
    OM Don,
    I bought my amplifier some three years ago, maybe it is out of production, but I will check the details and let you know.
    Tom
  • oreste g
    oreste g Member ✭✭
    thanks for the answers
    I checked on the kuhne site I also did not find info or dedicated RF amplifiers.
    At the moment I connected BNC XVTR of the 9700 to the Kuhne IF A,
    then connected PTT pin 3 of the Flexradio with DC Control.
    I drive with 70 w of the flex. I do not know if this is all correct and could cause breakages in long WSJTX transmissions.
    thanks
  • Mr Radio
    Mr Radio Member ✭✭✭
    OM Don,
    Possibly someone you can find a 2m amplifier here or place a >wanted< advertisement
    https://www.fa-kleinanzeigen.de/ if Kuhne does not manufacture them anymore.
    Tom
  • oreste g
    oreste g Member ✭✭
    hi DON thank you so much for the info, I think I will contact KUHNE and I hope they give me the correct configuration.
    I saw the product you recommended, thank you I did not know this product.
    I think however that I will try to use the 144PRO transverter because inside there is also a sequencer to drive the antenna preamplifier and PA.
    regards Oreste
  • Mr Radio
    Mr Radio Member ✭✭✭
    OM Don,
    It seems that Kuhne still manufacture 2m hi gain amplifiers for 6700
    https://shop.kuhne-electronic.com/kuhne/en/shop/leistungsverstaerker/MKU+PA+2M-60W+HY-2+VHF-MOSFET+Power+Amplifier/?card=1583
  • VE7ATJ_Don
    Tom.. thanks so much. Appreciate it.
    It's a little more expensive than the LDPA from Q5, but I'll definitely take a closer look.
