SmartSDR Mode Change
I just got my 8600 from Flex today and I am going through some tests to ensure I don't see any issues an one thing came up that made me want to query the group. As I recall on my 6600 when you changed the mode (LSB > CW) SmartSDR would display CW Object and when you changed back to LSB the Phone objects would display. I am seeing when I change modes the radio P/CW properties are not following.
Here I am on LSB and the CW properties are showing.
I found that if I switch band and then go back to the original band, the correct properties show.
I can create this at will. What am I missing.
thx
    Hi Mick, click on the TX indicator in the flag to make it the transmit slice, then you will see it change properly.
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    Doh!
    Thanks…
