SmartSDR Mode Change
Mick W8BE
I just got my 8600 from Flex today and I am going through some tests to ensure I don't see any issues an one thing came up that made me want to query the group. As I recall on my 6600 when you changed the mode (LSB > CW) SmartSDR would display CW Object and when you changed back to LSB the Phone objects would display. I am seeing when I change modes the radio P/CW properties are not following.
Here I am on LSB and the CW properties are showing.
I found that if I switch band and then go back to the original band, the correct properties show.
I can create this at will. What am I missing.
thx
Hi Mick, click on the TX indicator in the flag to make it the transmit slice, then you will see it change properly.
Doh!
Thanks…
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
