PGXL sudden power drops and HIGH SWR errors
Hi all,
We're having issues with our PGXL. This weekend extensively noticed during the CQ WPX SSB contest. Normal operation is Power out is about 1500 Watts or so. Then it often happens that the power is reduced to only ~300 Watts when starting to CQ, then during the CQ call, it shoots up to 1500 Watt again. Next CQ is normal. Then it can happen that suddenly during the CQ it drops from 1500 Watt to 300 W. This is as we speak happening on 10m. SWR is about 1,3:1 to 1,4:1, also when the issue occurs!
Since we've been seeing this before, so this morning I used a Bird 8251N dummy (1kw continuous) and tested with a short coax directly connected to the output of the PGXL (to exclude any issues with the antennas or 2 AG's and A/B swithces, power meter sensors, coaxes, antennes etc.) and I could reprocude this concern. SWR on the dummy was ~1,2:1 or so. I have captured this behaviour this morning in a video with my phone this morning (if needed I can sent).
Besides this, we've noticed that if the SWR on the antennes is just slightly above 1,5:1, intermittently we have a HIGH SWR message and the PGXL totally blocks TX.
I've checked the manual and it states the PGXL should only show this when the SWR gets up to 3,0:1 … but none of my antennas is that bad.
We've seen this behavour in both SSB and CW, on several bands, on several antennas. But as stated, most important, we've been able to reproduce it on a high power high quality Bird dummy load with a low SWR. Is there a possibility there is something wrong with the way the PGXL measures the SWR (realising that it measures very very fast, as mentioned by Mike), or any other internal issue?
Some further information:
- driving the PGXL with a Flex 6600.
- behind the PGXL we have 2x Antenna Genius, coupled via 2 A/B switches so we have 16 antenna ports in total. We're aware of the higher/lower bands distribution on the AG's antenna ports.
- measuring the power additionally with a WX0B Power Master II with 2 sensors, 1 in each coax from the PGXL.
We've bought this PGXL new from Wimo in Germany and it's still under warranty… anything that can be checked via remote? Or do I need to contact Wimo for sending it back for repair? Thanks in advance!
73 Frank ON9CC / OT6M
Frank,
I would request help desk support. From past conversations with help desk that indicated half the power supply is shutting down. Observe the VDD voltage on the amplifier. It is probably in the design to protect the LDMOSS. It may be in the timing or even a relay sticking which I have had. Try increasing the TX delay setting. Mine is 60 ms.
Do you have a Tuner Genius in the setup. That maybe a factor.
Bill
W9JJB
Frank,
I would be grateful if you would post here what action / remedy you have taken to solve your issue.
My PGXL is also quite new, having been bought from WiMo at the end of last year (in their Black Friday sale). Until 4 days ago there was not any problem but now something similar to your issue has started occurring.
On starting a transmission on any mode, the power is a few hundred watts less than it should be and then shoots up to what is expected. For example, testing a constant carrier mode into a dummy load (I chose FT8 and then CW), setting the power to 1100 watts out exhibits a starting output of circa 800 watts and then it will go to 1100.
My VDD voltage remains stable. I have tried increasing the TX delay.
I am currently in hospital from today until who knows when. I should have done something in the last 4 days but with my health issues I forgot. Now I have very limited access to internet / email and would really like to know any definitive answer as to who to contact and then my XYL can arrange shipping if indeed that is what will be required.
Erik.
Update on this issue: I've submitted a ticket to Flexradio and they stated that I've carried out all possible tests and they suspect an issue with the LDMOS transistors. They advised me to contact Wimo in Germany where I bought the PGXL. So I contacted Wimo and they asked me to ship it back to them for repair, which I will do in the next day or 2. I'll keep you posted.
@bahillen : we've already increased the delay but even then the issue keeps appearing.
Frank - hello, thank you for your update. My PGXL has same fault. Tim Ellison at Flex also advised me to contact WiMo but I sent WiMo email only yesterday so have yet to hear from them. Presumably I will also be sending it to them for repair in next days.
73 de Erik
Short update - shipped the PGXL back to Wimo and waiting for info …
Also my PGXL shipped to WiMo who acknowledged receipt. Waiting for info…
Erik EI4KF
Wimo just replied … they tested the amp and could not find any fault. They state "the test was done in 160m, 20m and 6m bands. Duration of each test was 4 minutes TX and 4min pause intervals."
I do NOT accept that answer as they didn't test is under normal contest operation is seems. It also does not respond to the issues of the intermittently HIGH SWR message and the PGXL totally blocking TX when the SWR is just above 1,5:1.
NOT a happy customer at this moment :(
-1 -
I have not yet heard from WiMo about my PGXL.
I am sure you have made clear to WiMo that your PGXL has a real problem. You have a video of it, I presume you have sent it to them. I sent video with my support request. Also you have the response from Flex which I hope you have forwarded to WiMo. Also, in the event of their support staff being unconvinced that there is an issue, you can as I have had to do in the past, direct an email personally to Volkmar Junge the Managing Director. Some time ago he sorted out an issue I had with equipment I had returned and was very helpful. So if all else fails, make sure you discuss with him. Good luck.
Erik.
Hi Erik,
I've just responded to them and explained in a lengthy reponse why I am not satisfied with their answer. I will give them a second chance to do a thourough diagnose. In their description of the test, they didn't even test under comparing conditions. Especially for these kind of intermittent issues, it's then very difficult to reproduce the concern. So I'll wait for their response and if that doesn't satisfy me, I'll sent a complaint to Volkmar (thanks for the tip! 😉).
73 Frank
OK Frank. Good luck. Another thought, if I were in your position, I would also be corresponding with 4O3A and see what they say. It is impossible for you to experience a problem and then have an engineer claim that there isn't one. Do they think you imagined it? I have found 4O3A also helpful so maybe a note to them if needed could help.
Keep us informed.
Erik
are you sure you don’t have an antenna issue that reveals itself under high power? I had this problem and sure enough there was a wire in my antenna that was arching under high power
My PGXL repair will have taken 6 weeks by the time WiMo send it back to me on Tuesday of next week. This is longer than I hoped, especially as the amp was only 4 months old and also considering the price paid. But it is what it is and to put into context, when I suffered numerous failures with a SPE 1.3 and 1.5 those repairs took 7 or 8 weeks each.
The engineer's report is
Bias current in "AB" was 1,6 amps instead of 2 amps.
Adjusted bias in AB and ABB. Checked Calibration data, it is correct.
Resoldered the LDMOSs and retested the amplifier, this time in multiple bands and 1 min on and 30sec off.
Test lasted 20 minutes. No power output issues.
Then we contacted Dragan at 4O3A and asked for any further test,
he has asked us to wait a few more days before sending it back to see
if there are any other cases from the field with this production batch.
This last comment arises from there being other PGXLs with faults, all bought from WiMo in 2024.
It is just one of those things. No company sets out to make defective equipment and repair times these days have lengthened due to pressures of work, availability of parts and so on. My PGXL never worked properly from the day it arrived but, even though I am annoyed at having lost 6 months warranty, hopefully from when I receive it back it will be as new and working without further issues.
OM Erik
WiMo ought to extend your warranty by six months or longer as a matter of courtesy/compensation.
Tom
Yes indeed Tom but they will not. It is not the first time with them either, same with a non-Flex product a few years ago. If I have more trouble with the PGXL within what I would consider the warranty period but they refuse to honor it, I will take the matter further. 4O3A may well underwrite warranty not provided by WiMo, I don't know because I haven't asked them but they rightly have a good reputation.
Erik
Yes, it is worth contacting OM Ranko at 4O3A , hope that they will be cooperative in contrast to WiMo.
Tom
Just a short update on this topic.
Initially it seemed that the PGXL had 2 issues: sudden power drops and a HIGH SWR message even when the SWR of the antennas was good (happened on multiple bands). Turned out that the sudden power drops were caused by my FLex 6600.
So Wimo fixed the PGXL (calibration datas adjusted, resoldered LDMOS and retested amplifier in multiple bands). The high SWR message hasn't occured since. Although my partial incorrect description of the issue, they repaired it at no cost.
Using Flex barefoot (since the PGXL was in repair) with max power, very sporadically I noticed a power drop from ~90W to ~30W ! Of course I didn’t drive the PGXL with that high power, but if this happens with high power, this most likely will also happen with lower power, when driving the PGXL. That will then explain why the PGXL power output drops of course (of which I informed Wimo and 4O3A as soon as I noticed this).
So I sent the Flex to the Flex EU Service Center (Norbert Wrede) in Germany. Norbert quickly fixed the Flex (Changed PA bloc, Changed multiple caps on LPF board) and now both are working OK so far (as far as we could test in IARU contest).
So I'm happy that all is working again :) Thanks to all for giving tips in order to fix this!
73 Frank ON9CC
- 362 Community Topics
- 623 The Flea Market
- 8.1K Software
- 54 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 9.2K Radios and Accessories
- 28 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 290 Shack Infrastructure
- 204 Networking
- 764 Peripherals & Station Integration
- 986 Third-Party Software
