Using Multiflex (Connect prompt)
I normally use "Multi-Flex" a lot. When I go out of town the radio & TGXL stay on along with the PC. And smart-link version 3.8.23 running on the PC. Then I use the iPhone or iPad or maestro to connect to the radio away from home. Normally most of the time with my Apple iPhone 14 Pro. Using my Apple air Pod pros or the Bluetooth surround sound in the SUV. So since Multi-Flex works why do I still get this prompt every time I connect ?
Thank you.
one reason is you can take complete control of ALL of it capabilities as a single user and not share…by disconnecting the other user… i have done that with my 6600m when i want to run macssdr with all for slices and not the two share slices
another maybe a user has not logged out properly and you want in so you can just disconnect that one
Paul K3SF
- 396 Community Topics
- 676 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 327 FLEX-8000 Signature Series
- 985 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 314 Shack Infrastructure
- 219 Networking
- 146 Amateur Radio Interests
