8600 Time Server
Alan
Alan Member ✭✭✭✭
I would like to try using the built in 8600 Time Server.
First question, is there, yet, a hardware manual for the 8600 that likely contains time server information?
If not yet, could someone post the necessary instruction to use the time server?
Alan. WA9WUD
Best Answers
    edited December 2024 Answer ✓
    HI Alan, here is a link to the new 8000 series hardware manual:
    https://www.flexradio.com/documentation/flex-8000-hardware-reference-manual/
    See page 133 for NTP info.
    Edit: Sorry I accidentally sent this before I finished…
    Go to Control Panel and select Clock and Region:
    Click Set the time and date and select the Internet Time tab.
    Click Change Settings. In the Server: box, enter the IP address of your Flex 8000 series radio. In my example below, change time.nist.gov to the IP address.
  • Bill NE1B
    Bill NE1B Member ✭✭✭
    I have found the information in the FLEX-8000 Hardware Reference Manual is inadequate for setting it up as an NTP Server.
    If I setup the Windows PC based on the Windows Internet Time, the reference is time.windows.com or time.nist.gov
    All are Internet time based, Stratum 3. The FLEX 8000 having a GNSS receiver is a Stratum 1 clock, therefore better. So, if I change the reference setting on my PC to the IP address for the FLEX I get a message from TIME.IS that my time is exact and the majority of FT8 decodes are 0.0 to a maximum of .3 seconds differential. That is great! But I would like to know:
    1. What happens if I turn off the radio?
    2. What happens if the radio fails, my GPS reception fails?
    3. Is there a backup hierarchy?
    Some hams recommend using Meinberg, others recommend using Dimension 4 for more flexibility.
    I find Meinberg confusing to setup. I am not a Linux programmer.
    Dimension 4 is easy to setup as having a Windows GUI. What are the PROS and CONS?
  • Bill NE1B
    Thanks Erik. Interesting thought. I will try that!
    Bill
