SmartSDR Doesn't Load
New laptop. I download SmartSDR 3.8.23. I click on the downloader and it asks me if I want to allow changed. Yes. It then opens the License Agreement and I accept. It asks for file location and I use what it suggests, hit next. Select components and go with default selections and hit next. Create desktop shortcut, yes. Ready to install popup and hit Install. The Installing screen opens for a few seconds then closes and nothing else happens. I have allowed 3rd party apps.
Any suggestions?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    I would suggest you open a Help Desk ticket to get the Flex gurus to give you a hand. They are excellent at working through the various vagaries of Windows installations.
    One thing to look at tho, is whether Core isolation is turned on (Under Settings/Privacy & security/Device security. It should be turned off. If it's turned on, SmartSDR and some of the drivers (most notably the DAX drivers) will not install correctly.
