Logger32 for Flexradio
Good Evening,
I was writing to ask whether anyone out in Flexradio Land is using Logger32 for Flexradio? I was questioning how easy it was to set up? And also, your thoughts on the software interacting with the Flexradio 6000 series?
Thanks!
Mark Griffin, KB3Z
Mark, I have used Logger 32 for a long time with my 6500. It works just fine. Create a CAT port and then configure for it in Logger 32. They will track one another in frequency.
If you like, I can fire up the rig in the morning and give you the full details. Jim KD1I
I have been using Logger32 for several years with the 6400M (V2.10.1). I also used it with the 6500. It works great on both radios. It is very easy to setup and is also extremely customizable. Clicking on a spot from Logger32 will take you the the desired band, frequency and mode on the Flex.
This is how I have it setup but the possibilities are endless.
There was an error rendering this rich post.
