Flex Radio 8400M manual
What you are looking for is the 6400M/6600M user guide.
Until new documentation is available, the 6000 series documentation is more than adequate to get you going.
The M version front panel and the Maestro are essentially the same thing, so there is not a separate manual for each.
The hardware manual will change (GNSS antenna is new), but most things are still valid.
At the moment, there is very little difference in the functionality of the 8000 vs. 6000 series radios. What is new is the potential for new things (Adaptive Pre-Distortion, faster/better noise reduction, etc.).
Spending some time with these manuals will make your initial time with your new radio much more pleasant. I had to wait a few weeks for my 6400 when I bought it in 2020. I spent that time going through all of the manuals. When I got the radio, it was a real joy to operate because I wasn't hunting around for how to do the basic things.
Best of luck, and I hope you get your new rig soon!
If you go to the Flex Radio website (https://www.flexradio.com) and click Support>Documentation at the top it will take you to all of Flex's documentation. Search for what you want in there. For example here: you can find their "Flex-8000 Family Quick Start Guide". There are also documents for SSDR, Maestro, etc. They may not have updated the hardware specific documents yet as the whole 8XXX story is still coming together as you'd expect. So you might find the most recent 6400 manual the most applicable for your case at the moment. But it will be pretty close for now.
GL Russ KR6W
Thanks so much to all that replied. I did find the 6000 user guide and will have to use that until they get the updated 8000 out. I understand they operated the same.0
The hardware reference manual for the 8000 is now available.
The Flex manuals are the best ham radio documentation I’ve ever used. Most others are mostly reference, like trying to learn a language from a dictionary. Flex is much closer th a how-to procedure document.
- 359 Community Topics
- 620 The Flea Market
- 8K Software
- 25 SmartSDR+
- 6.3K SmartSDR for Windows
- 415 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 901 Genius Products
- 325 Tuner Genius XL
- 117 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 981 Third-Party Software
