Can you mute headsets that are plugged into the Maestro when listening to the front speaker?
David43
David43 Member ✭✭
Can you mute headsets that are plugged into the Maestro when listening to the front speaker? Under the Audio menu the MUTE button has no effect when selected.
  • Al K0VM
    Al K0VM Member ✭✭✭
    David,
    The Mute functions on the MaestroC Audio panel, refer to the Radio connected audio devices. There is no equivalent for the Maestro connected audio output devices. Not way to mute the Maestro head phones independently of the Maestro Speaker.
    AL, K0VM
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    on the Maestro C, if you select main audio out—Maestro on the audio panel and select Mute for Headphone and Enabled for front speaker, that doesn’t do the trick?
    I guess you are correct, after playing with it.
  • Erik Carling EI4KF
    Use an inline mute switch. Cheap, easy, has volume which you don't need but crucially has the one button mute on/off.
