Can you mute headsets that are plugged into the Maestro when listening to the front speaker?
David,
The Mute functions on the MaestroC Audio panel, refer to the Radio connected audio devices. There is no equivalent for the Maestro connected audio output devices. Not way to mute the Maestro head phones independently of the Maestro Speaker.
AL, K0VM
on the Maestro C, if you select main audio out—Maestro on the audio panel and select Mute for Headphone and Enabled for front speaker, that doesn’t do the trick?
I guess you are correct, after playing with it.
Use an inline mute switch. Cheap, easy, has volume which you don't need but crucially has the one button mute on/off.
- 637 The Flea Market
- 144 SmartSDR+
- 432 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
