Setting up Remotehams access under v. 2.0
2»
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    Thanks I just read up on that after reading your post. So you are sharing one ip address with multiple subscribers. From what I read they mentioned using a VPN but I assume you already ruled that out. If you’re carrier offers a business service that should provide you a static wan ip address.
    Sorry to hear your carrier is the limitation.
    regards
  • normancyyj
    normancyyj Member ✭✭
    Yes and the business account will offer a static IP address but I don't want the expense almost 3x the cost and no other advantages. I am happy with what I have working now. Full control over the 6600 using Chrome Remote and RemAud, works great.
