8600m standalone and PC simultaneously
Steve,
Yes you can.. The radio portion of the 8600m is a server that can support up to two graphic client at the same time ( its called MultiFlex ). SSDR on the PC is a graphic client and the control panel on the 8600M is another graphic client. Simultaneously, the server can also support several non-graphic clients such as SSDR CAT and SSDR DAX. Just start up the clients that you need. You just need to be aware that some of the server's resources are shared between the clients and others used in common.
AL, K0VM
NOTE: The PC and Radio Front Panel will operate INDEPENDENTLY of each other. In other words — The two "Clients" do NOT mirror each other.
So . . . Slice A on the Front Panel is different from the Slice A on the Computer (SmartSDR for Windows or Mac).
ALSO: You cannot use DAX or CAT on the computer to link to BOTH clients at the same time, because you can only run ONE instance of DAX and CAT at the same time, and that instance can only link to one of the "Clients" at the same time (Either the Radio Front Panel, or the Computer).
Thanks for the info. So I can set up wsjtx on the PC and let that do it's thing whilst I dx on the radio. So can I transmit on both?0
Hi Steve, you can transmit from either but not simultaneously. The 8600 has 4 receivers but only one transmitter.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
