Connecting flex radio
Connect your radio ethernet cable to your LAN router/WiFi. Connect your laptop with Wifi to the router.
AL, K0VM
I did say that I couldn't connect radio to the router0
Hi Steve… Is there any way you could route a 'longish' cable between the rooms? Alternatively depending on which Flex you have, (i.e. a non-M version), you could, like I do, put the radio in a closet or near the router and just forget about it — essentially running it just as a 'server'. Then you can set up your laptop anywhere you want.
Eric's suggestion should work as well.
Unfortunately my radio is upstairs and my router downstairs. I didn't know if there was another around0
Steve,
Sorry I missed that point. You may be able to find a wifi range extender that has an ethernet port on it also.
So you get wifi from your LAN router/wifi to the extender and then ethernet cable from the extender to the radio.
I have a TPLink RE505x that should work but don't use it for that purpose.
AL, K0VM
OR… If you don't need an internet connection, You could put a spare router/wifi device next to the radio
and connect the lap top wifi and the radio cable to that. It would be an isolated LAN.
AL, K0VM
There was an error rendering this rich post.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
