How do I set the STATION NAME?
George Brown
George Brown Member ✭✭
I have a new 6400, software is 3.0.27.  How do I set the STATION NAME field.  Right now it has 'DESKTOP K7OQDSF' in the field and I have no idea how to change that.
  • N2TU
    N2TU Company Adviser ✭✭
    edited July 2019
    If you are referring to the Sattion:XXXXX on the bottom of SSDR, just type over it.
    Lou N2TU
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    Go to settings, then radio setup, then change the information in the "Radio identification"
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    edited July 2019
    The STATION NAME initially is actually the name of the Computer that is connected to the Radio. You can change it by just typing the name you want by just typing over it.
  • John WA7UAR
    John WA7UAR Member ✭✭✭
    edited June 2020
    But when I change it, and then quit SmartSDR and restart, the old STATION NAME comes right back.
    I had thought that it was supposed to pick up the name of my PC (not my login name, my PC name) because they were the same at one point. But even after I changed my PC name, and then started SmartSDR v3.1.7, my station name was still my old PC name. Can anyone else confirm if changing their PC name does, or does not, change their station name?
  • Brian Gohl - AI6US
    Brian Gohl - AI6US Member
    edited June 2020
    Type the new name in the field beside STATION: then Enter. The name is stored and displayed when SmartSDR is restarted. I confirm that the station name is not associated with the PC name.
  • Tjerk
    Tjerk Member ✭✭
    edited February 2025
    In the middle at the bottom of the SmartSDR screen next to Station should be the name of the computer you are using.
    Just type over the name to change it.
    Tjerk ZS1J
  • K5XH
    K5XH Member ✭✭
    You must hit ENTER after you change the name.
