DAX Driver Error after Windows 11 Update
Rich - N5ZC
Rich - N5ZC Member ✭✭✭
edited February 2025 in SmartSDR for Windows
I'm getting the following error after a WIndows 11 update.
I've done a search on how to fix this. I've ensured that the microphone is allowed to access DAX and it appears that ALLOW is selected for DAX, however, I still get the error.
Ideas on how to resolve?
Rich - N5ZC
    Hi Rich, This is probably a Win 11 Core Isolation setting issue. I think that if you turn off Core Isolation in Win 11, it will fix your problem. I don't have a Win 11 machine, so I can't tell you how to do this, but I am sure the solution is out on the web somewhere.
  • Rich - N5ZC
    Len,
    Thanks for the idea. I just checked the core isolation option and its off.
    Ah, OK, then I would submit a help desk ticket.
  • johnn1jm
    johnn1jm Member ✭✭✭
    Under Device Security-Core isolation-Memory Integrity is off, correct?
    John N1JM
  • Rich - N5ZC
    N1JM, yes its off.
    I placed a help ticket yesterday. I'm sure this will be chalked up to 'Windows strikes again'
    Rich - N5ZC
  • Rich - N5ZC
    As usual the help desk took care of business.
    I had to un-install and re-install the DAX drivers.
    Please note that if this happens to your setup, you need to contact the help desk first before going through this procedure as there may be a different fix.
    Rich - N5ZC
