Working with WSJT-X
AA1SL
AA1SL Member ✭✭
edited February 2025 in Third-Party Software
Hello,
I was able to setup Flex 6400 with Win11 WSJT-X and it worked fine until I used iPad with SDR app.
Now when I fire up WSJT-X on Win11 PC, I can see the traffic but no transmission.
Any suggestions how to fix it? I restarted both, radio and PC and it wont TX on Win11 software. Meanwhile iPad SDR works like a charm.
Thanks!
73, De AA1SL
Serhiy
  • Erik Carling EI4KF
    Is DAX set correctly and turned on?
  • AA1SL
    AA1SL Member ✭✭
    Yeap, to 1 on radio and DAX app.
    same CAT
    Nothing was changed since first and successful setup.
    Same setting. Everything works fine except transmissions.
  • km9r.mike
    km9r.mike Member ✭✭
    Double check in WSJT-X settings radio tab that CAT is still selected for PTT and audio tab has DAX AUDIO TX selected for output. Go back to radio tab and test CAT and test PTT. If those both test good the only thing left to adjust is your DAX TX level.
  • AA1SL
    AA1SL Member ✭✭
    I found the reason - I had Slice Master installed and from now on I’m expected to fire up first that app and after that SDR on Flex 6400 worked like a charm
