Can button colors on the SmartSDR screen be changed
Michael Thursby
I am slightly color blind and the colors of some of the buttons on the SmartSDR display are particularily hard to read. Anything that is green is very muddy.
Specifically the Receive antenna pulldown is almost unreadable I have to stand right next to the monitor to see the selections. The graphic equalizer on/off button is also a problem I can only tell if it is on by listening to the audio. I think you see my problem. Is there any way to set these colors that would have more contrast for my type of color blindness? My red and Green sensor spectrum overlap so some colors of green are hard to see.
Mike K4ZEA
Mike K4ZEA
Not from within SmartSDR but I have Protanopia and use the Color Filters in W11 to good effect. They are switchable on/off with a keyboard shortcut (requires enabling) so that what I need for SmartSDR is not necessarily applied to other software that I can manage without adjustment. In W11 go to Settings / Accessibility / Color Filters.
