No sound from Flex 6400
AA1SL
Hello, I just bought Flex 6400. After initial install, I could hear stations and I had to reset the radio to factory settings and now there is no sound at all. I can see waterfall activity but no sound.
Any suggestons?
Serhiy
73, de AA1SL
Any suggestons?
Serhiy
73, de AA1SL
Hi Serhiy, you have the PC Audio button selected (upper right hand corner of screen) so your audio will come through your PC. If you want to use powered speakers connected to the back of the radio, then un-select PC Audio.
If you do want the audio to come through the PC speakers, then make sure that your default playback device is your speakers. Also, make sure that you have your speakers set to be the default playback device in your computer settings. When I use PC Audio, I have to turn my PC volume up to 100% and run the volume slider at a much higher value in SmartSDR.
Hi Serhiy, can you post a screenshot of SmartSDR?
null
Hi Len, just updated in my main post.
Serhiy AA1SL0
- 652 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
