My ipad won't connect with smart sdr but windows smartconnect does
Q-On my iPAD (7th Gen) I D/L the FlexRadio access app ($60). Started it up and logged in to FlexRadio Access. Touch Panadaptor and it says you are not currently connected. Tap here to connect. I do that and my smartlink 6300 comes up both the DEMO mode and the Flex 6300 with a 'blue' dot and explanation point with ip and a blue i with a circle around it.
When I touch that to connect it goes back to the 'You are not connected, Tap here to connect loop' What am I missing? I can't get to the FLEX although it's listed with the exclamation point.
This HAS to be a setting on the ipad or something. I have not registered the IOS except when I bought it thru itunes. I don't see any instructions. Also does FLEX support this IOS app? Can I submit a ticket for this?
Thanks in advance for any help all.
73 de WB4KPS
Yea, something is not right. I am having a similar problem. It was working fine but recently, I can see it on Smartlink but can not connect. On the local network I can not see the radio at all.
What iOS are you on? I believe the latest iOS (14) has caused an issue with connecting. There is a work around VA3MW posted on the Facebook site.
Tim VE6SH
Here is Mike' s post on the Facebook site (which comes from Marcus):
Michael WalkerFlexRadio Enthusiasts
SMARTSDR IS COMPATIBLE TO IOS 14
However, due to a bug in iOS 14 it might happen that you can’t use SmartSDR to connect to your local Radio.
But there is a simple solutions. Just change the App to use a fixed IP Address of your Radio. For this, just go to Settings -> Show Extended Settings and select “Fixed” for “LAN mode”. Then, enter the IP Address of your Radio in the field below named “Network”. (No change on your Radio is required for this)
Now, you should be able to connect to your Radio again.
Once you do that, you may get asked by iOS for permission to access your local network by the App. Once you confirm this and gave the App permission, you can even turn back off the fixed IP LAN mode and change it back to “Discover” which is the recommended setting.
You will now also find a new Setting in the iOS Settings under Privacy -> Local Network.
Here, you should see an entry for SmartSDR which should be enabled. If you don’t see this entry, continue to use the fixed IP until you get the permission question from iOS.
On this screen, you can also re-enable Local Network access if you accidentally dismissed the permission question.
I expect this but to be fixed in the next iOS version but in the meantime, the aforementioned procedure will solve this problem.
73, Marcus
I am using V14 and when I enter the radio IP and try to connect it FINDS the radio and tries to connect. It says connecting but in a few seconds it says 'search error'. I'm using the rig remotely...and when I'm at the remote site it connects fine and works on the LAN. But not so going thru over the web outside of the local LAN. Other ideas??0
I am using the newest version on my iPad. Worked before but now no radios are shown to connect to. Guess I got took when I bought program. Any help is appreciated. Email me at jrbluz2@aol.com
hey wayne if you want help you will need to provide more detailed info
Like Ipad model, Ios version, ios SSDR version for starter
then method of network connection..like wifi, 5g cell fone….
and
whether doing Lan , Wan , smartlink…
also pictures of what you are doing also help us help you to debug…
foe example…this is how to select DAX channel and seeing it operate with WSJTx
pictures really really help both ways
Paul K3SF
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
