SSRD 2.12.0 removed from Maestro??
EDIT After restarting my Maestro 4 times, I did start once more to find the serial number while submitting a ticket, and just like magic my Maestro did auto connect using 2.12.0.
Still not sure why 2.12.0 does not show on list when NOT auto connect is enabled.
Was about to use my Maestro A, when it tells me I cannot connect until I upgrade to 2.12.1. Auto connect fails.
I have been using 2.12.0 since its release and have not the need to upgrade to 2.12.1 as I do not have MaestroC. Both radio and my Maestro do have V 2.12.0 installed but Maestro refuses to connect, does not list 2.12.0 as an alternative.
How do I proceed to use 2.12.0 and NOT upgrade to 2.12.1???
/Lasse SM5GLC
I had a very similar experience this morning with My Flex 6400M. When i turned on my PC I could not find the SSDR 2.12.0 Icon which has always been on the desktop and in the taskbar. I was in the process of getting on the radio with some friends so I thought I would just run from the front panel. No, that was not possible. The only SSDR version listed was 2.12.1 but no 2.12.0 which basically meant a mandatory upgrade. I decided to run the update to 2.12.1 and also installed Smart SSDR 2.12.1 on the PC. Everything worked as it should and I was able to get on the air. I am curious as to how the SSDR version 2.12.0 was removed from my PC and why it was no longer available on the radio itself. I imagine I must have missed a message from Flex recently.
Digging a bit deeper… Running Maestro and 2.12.0 I selected "Switch Radio" and my Maestro did reboot, and it could not connect to my radio as 2.12.0 was not there. But managed to enable the auto connect and then reboot Maestro once again, and magically it did connect.
I am sure there is a good explanation to this :)
/Lasse SM5GLC
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
