RX Filter Bandwidths
Opathy
I'm fairly new to SmartSDR so is there a way to change the default low cut settings on the RX filter bandwidths from 100 hz? I just find it to bassy for my everyday usage. I know you can drag the pan adapter window etc., but its required every time i change the preset bandwidths
The simplest way is to use the "Memory" function.
You can program the Receive filter bandwidth setting into a memory and use the memory to move your radio's slice to your desired frequency with the desired Receive filter bandwidth settings.0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 62 Aurora
- 975 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
