Another PSL Shutdown
Rick Hadley - W0FG
Rick Hadley - W0FG Member ✭✭
edited March 2019 in SmartSDR for Windows
Got another "Shutting Down..." PSL error this morning. I'm using a different, dedicated power supply, so I know it's not the PS itself. This time the message was PSL Error 13V8B-9.37 check fuse. I killed the PS switch and after restoring power & rebooting the computer everything was back to normal. There are no fuses/self-resetting circuit breakers in the rig are there? I'm assuming it may be an RFI problem, but don't quite know where to start looking for the culprit.
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    You should submit a support ticket. There is a fix that Flex can help you with. Mack W4AX Alpha Tester
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    Rick, I was having shutdowns due to RFI and they would happen as soon as I tapped the key. I think you also mentioned that in another post. If you suspect it is an RFI problem, you might want to take a look at this posting. It list the symptoms I was experiencing and the solution that worked for me. http://community.flexradio.com/flexradio/topics/rfi_shuts_down_the_6k_fast Regards, Al / NN4ZZ
  • Tim - W4TME
    edited March 2017
    This issue has been transferred to the HelpDesk.
  • Bvarcd
    Bvarcd Member ✭✭
    WHEW! My Flex is up and running. (Was showing: ERROR MESSAGE PSL 13V8B 09.4b). I bypassed all fuses and connected it directly to my power supply and all looks normal. I'll do some fuse cleaning. Thanks to interested parties.
  • W2PP
    W2PP Member ✭✭✭
    you bypassed all the fuses?????
    Risky
