JTDX freq input on SmartSDR 8600 with follow to JTDX
ad4vxtom
I received my 8600 on Christmas Eve. Formerly with my 6400, I could manually enter a frequency on the SmartSDR panel and the JTDX or WSJT-X would follow. As many more rare DX stations use non-standard frequencies. Since, I've swapped the 6400 with the 8600 and I transmit, JTDX reverts back to the standard frequency. Example, J75K was transmitting on 14.084, I can decode J75K, I go to transmit and JTDX transmits on 14.074. How do I get this fixed. Happens with both JTDX and WSJT-X, so I believe it's some "switch" in the SmartSDR that needs to be flipped. Worked fine with my 6400, but not now.
On the main screen, make sure that the "TX/RX SPLIT" button is activated.
Good luck
Gordon, ve7on
