Flex 6400 and transverter and CTCSS
Hello to all Readers
Does anyone have this combination in operation and can provide experience?
Above all, I would be interested to know whether relay operation is possible with the 1750Hz tone and CTCSS. Does the 6400 provide this?
Best Answers
Hi Daniel, repeater operation is possible with this setup. I have a 6400 and do not see the 1750 Hz tone in the list of CTCSS TX tones, so I am not sure if the TURF file for your part of the world provides it or not.
Make sure to check the RCA TX box in TX Band Settings that corresponds with your PTT line. I use RCA TX2 for my transverter.
You might also want to try my FlexRepeaterSpots utility:
https://community.flexradio.com/discussion/8029504/flex-repeater-spots-utility#latest
I found it here:
https://community.flexradio.com/discussion/8024309/logger32-spots-in-smartsdr
Daniel
HB9DDS
Hello Len
Thanks for that Information (FlexRepeaterSpots).
Is there also a solution for Spots from DX Cluster in the SmartSDR screen?
Daniel
HB9DDS
Yes! From section 30 of the Software User's Guide:
I use ACLog from N3FJP to post spots on my SmartSDR screen.
Hi Len
Thanks again.
"Some of these programs include Logger32"
How do Logger32 communicate withe SmartSDR?
Daniel
HB9DDS
I believe that Logger32 is on the list of compatible logging programs.
They would use the Flex API. Check the Logger32 documentation to see how to set it up.
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 68 SmartSDR+
- 181 SmartSDR for Maestro and M models
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 233 FLEX-8000 Signature Series
- 930 Maestro
- 908 Genius Products
- 328 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
