The Mystery of SmartLink
Hello to All
I have a 6400, Purchase Date unknown.
Do I need a License for smart link or just register it? The red light is coming up. No green….
And what means License exactly? To buy one?
I'm lost. A little bit
Daniel
HB9DDS
No license necessary. Just a matter of registering the radio to smartlink, which is a security feature. Registration pretty much has to be done when local to the radio. Just understand that smartlink is only used for remote operation, not when the radio is on the same lan as the computer.
Hello John
Thanks for the info. I only ask because I read somewhere that you have to buy a license from the date of purchase of the Flex.
But somehow it doesn't work with Smart Link. I have the Flex 6400 and the PC plugged into the same LAN at home. So I can operate it easily. Working on a Mac with Parallels and Windows 10.
Now when I look at the Smart CAT and DAX on the computer (at home), I see this:It searches and searches for the SmartLink connection. I assume to the server.
Either I am doing something wrong, don't understand SmartLink or there is a technical problem.
But if the connection is established, how can I connect my Flex 6400 from anywhere in the world? I use an iPab with Smart SDR for iOS (Marcus Roskosch).
What do I need to activate and where?
Daniel
HB9DDS
But somehow it doesn't work with Smart Link. I have the Flex 6400 and the PC plugged into the same LAN at home. I can operate it easily there. Running on a MacMini with Parallels Desktop and Windows 10
But if the connection is up, how can I connect my Flex 6400 from anywhere in the world (via WLAN in a Hotel or Caffee Shop ….. via or GSM 4/5)? I use an iPab with Smart SDR for iOS (Marcus Roskosch).
What do I have to activate where
Running the Network Settings Test, but not get a green response.
A red test result means that the connection will not work with the current configuration on the radio network.
Hover the mouse cursor over the red result indicator to open a window containing details about the test
failure. These details may help you to understand how to correct the problem. Take note of the details
in case you need to open a Help Desk support ticket.To avoid connection issues and obtain a good test result (green), enable UPnP (Universal Plug n Play) on
your router if it is supported or use the Manual Port Forwarding option (see below).For a reliable connection without UPnP, you will need to use Manual Port Forwarding. To use Manual
Port Forwarding, you will need to pick one TCP port number (e.g. 4994) and one UDP port number (e.g.
4993) for SmartLink to use. Select Manual Port Forwarding then enter the port numbers you have chosen in the TCP and UDP Port fields. Click the Save button. The remainder of this procedure is done to the
configuration settings of your router. Details for setting up port forwarding is in this document,or see this video
In addition to port forwarding, your radio should be assigned a Static DHCP address by
the router to avoid occasional breaks in the SmartLink connection caused by changes to the radio’s IP
address.Don't be put off opening a Help Desk Ticket - Flex support is excellent.
Hello Erik
Thanks for the explanations and the video. The solution to the problem has been solved with “Switch on UPnP on the router”.
At first it didn't work, but the router had to digest that first and communicate with the Flex. That takes a while.
Now I have made an FT8 QSO externally from the streetcar.
Another tip for all those who operate remotely. It doesn't make sense to switch the Flex on and off remotely, but rather the power supply unit. Because when it switches on, the Flex also switches on. It is safer.
Thanks again for your help.
Daniel
HB9DDS
Hi Daniel, it is not recommended to power your radio on and off that way. The radio is a server, and needs to power on and off gracefully by either pressing the power button on the front, or using the REM ON jack on the back.
Once the radio is finished with its shutdown routine, the power supply can be safely shut off.
Len, I mean, of course, with the “shorting plug” plugged into the remote ON.
What speaks against it?
Or you can switch both. Power supply unit and Flex on and off separately remotely.
Hi Daniel, turning the rig on that way is probably OK. I don't do it because I don't know what happens when the radio is at low voltage while the power supply ramps up.
Turning the rig off by shutting off the power supply puts you at risk of corrupting the memory card. It would be like shutting off a desktop computer by pulling the power cord. The radio needs time to save persistence values before it is fully powered down.
A 4 channel, wifi connected remote network switch is relatively inexpensive ($20 USD) and gives you the ability to remotely power the rig on and off safely. I use one channel to control REM ON and the other three channels to switch among antennas.
Hello Len (again)
If I first switch off the Flex 6400 with Remote ON and then the power supply, this should not be a problem
And accordingly when switching on first the power supply and then the Flex 644.
The idea behind this is as follows:
If you are away for a few days or weeks (overseas etc). Then it is also safer to switch off the power supply unit at the same time.Unfortunately I can't
4CH WiFi RF Wireless Switch Relay, Inching Self-Locking Interlock Mode, for access control, smart garage door, compatible with Alexa Goolge Home
via Amazon. An account that I wanted to activate or set up a new one is immediately locked. No idea why.
Daniel
HB9DDS
Turning the radio off by simply turning off the power supply is the equivalent of shutting down your computer by yanking the power cord from the wall. It doesn't let the radio shut down "gracefully" and doesn't allow it to make final writes to the SD Card as it shuts down.
Hello Ken
As described above, this procedure would be an alternative:
If I first switch off the Flex 6400 with Remote ON and then the power supply, this should not be a problem. And accordingly when switching on first the power supply and then the Flex 644.
Daniel
HB9DDS
Question: Is the “Remote ON” a soft switch off?
Daniel
HB9DDS
Yes, the REM ON and power button both behave the same. They both provide a graceful shutdown.
How I do mine is probably a more sure way to NOT damage anything turn off the Radio with the Remote power and WAIT for 2 minutes, Then I turn off a Hi current relay like a vehicle headlight Relay to interrupt the 14V DC then I have a 3rd switch to shut down the DC Power Supply using the AC power remote switch.
When I turn things back on I do it as above but in reverse order, AC to Power Supply WAIT 30 Seconds, Then the FLEX main Power and WAIT for about 2 minutes then I turn the Remote switch ON.
Waiting allows the Radio to totally shut down and boot properly when going from ON to OFF and then OFF to ON.
I have ran mine like this for a VERY LONG time (Over 5 Years) and it works perfectly running Remote like I am.
Happy Holidays
Bret / WX7Y
- 310 Community Topics
- 566 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 385 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 8.9K Radios and Accessories
- 108 FLEX-8000 Signature Series
- 886 Maestro
- 49 FlexControl
- 841 Genius Products
- 433 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 266 Shack Infrastructure
- 187 Networking
- 427 Remote Operation (SmartLink)
- 132 Contesting
- 685 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 914 Third-Party Software
