RESISTIVE TO DIGITAL CONVERTER
Could not find this posting so posting again.
I believe I am describing or looking for the correct unit for my needs.
Without having to change my antenna system rotors which simply supply a variable resistance reading used to indicate the antenna direction. My hope is to convert this resistive value to a digital value. This value with the help of software and a LAN ethernet connection to my computer provide a number or reading that I could convert to a compass antenna direction.
I would prefer a plug and play unit with supplied software compatible with the Windows11 operating platform.
The function seems simple enough but finding the unit that will do the job has become complicated. I hope that someone out there can supply me with information to the unit I need. I have three rotors to monitor.
Thanks for reading my request,
Rich C AA2MF
Hi Rich, check out PstRotatorAz. I use it with my TailTwister T2X rotator with a RotorEZ board in it.
What rotators do you have?
Hi Len KD0RC,
I have a Hygain Ham M and two TIG Ring Rotors
Rich AA2MF
Hi Rich, the Ham-M will work with Rotor-EZ and pstRotator. You can check with both of those companies and TIC to see if your TIC Rings will work with them.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
