HowTo: PTT on Maestro but no audio?
brucew2024
in Maestro
Have a footswitch on Maestro C but microphone output only works if I press the MOX switch. How to fix this please?
you are using mic into radio and not Maestro? If so, plug foot switch into radio.
73 Dave wo2x
This does not provide a solution because then the slice has to be set to Tx on the radio leaving the Maestro, useless.
Well I figured it out. Somehow I lost the setting for the Local PTT in the Multiflex settings. All is well again in the HAMverse.
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
